The Blinq LTE that I am connecting to has 2 APNs, when I goto add a second APN I get a message that says only one APN is supported. Is this normal? Why wouldnt I be able to use 2 APNs
[admin@MikroTik] /interface lte> /interface lte set lte1 apn-profiles=apn1,apn2
failure: Only single APN is supported
Also when I try to change band I just get a blank window
[admin@MikroTik] /interface lte> set 0 band=
Band ::= Band[,Band]
Band ::=
