RBM11G and Fibocom NL668-LA compatibility
Hola a todos, tengo una RouterBoard M11G con un módulo LTE Fibocom NL668-LA, el problema es que el módulo no es reconocido como una interfaz LTE. Sin embargo, dicho módulo sí aparece en /system/resource/usb/. ¿Qué debo hacer para que el módulo sea reconocido correctamente como una interfaz LTE?. Gracias por su ayuda.
Hello everyone, I have a RouterBoard M11G with a Fibocom NL668-LA LTE module, the problem is that the module is not recognized as an LTE interface. However, this module does appear in /system/resource/usb/. What should I do so that the module is correctly recognized as an LTE interface? Thanks for your help.
This means ROS can see the USB device but does not have a driver to actually use it as a cellular modem.
ROS is limited to a set of supported devices and no additional drivers can be added by the user.
There is a list of supported devices:
https://help.mikrotik.com/docs/display/ROS/Peripherals
