rbm33g and m.2 slot problem
I received my rbm33g today. I tried to install a KingDian m.2 32gb NGFF ssd to the m.2 pcie slot but it doesnt work. I cant see the drive appear in /system/disk/. if i try a sd card it works like a charm. But the ssd never appear. What do i do wrong?
Quite probably ROS doesn’t include appropriate driver for M.2 SSDs. But you should check with support@mikrotik.com to be sure.
Before anyone asks why HW ports are there if the devices are not supported: they will most probably work after an unicorn pulls ROS7 out of a rainbow …
Hi ubikrotik,
I had a similar issue a few months ago:
http://forum.mikrotik.com/t/m33g-m-2-sata-support/119731/3
Doneware pointed out, that the M33G only supports m.2 ssds with pcie interface - all ngff devices listed on Kingdian’s website have sata interfaces.
Cheers.
