RBM33g. two miniPCIe and USB port used.
Hello.everyone!
I have RBM33g with R11e-2HPnD and R11e-LTE installed in miniPCIe slots. Everything working fine, but I need one more LTE connection. I wonder if I can use USB port for LTE modem with its own sim slot in such case?
No. You can use miniPCIe slot OR USB port, not both at same time.
Regards.
Yes you can. Only USB lines are shared between mPCIe slot 1 and USB port. If lte card is installed in mPCIe2 and wireless card in mPCIe1 (wireless cards utilize PCI lines) USB can be used for LTE modem.
Sorry, my mistake.
As you can see, USB3.0 is directly connected to SoC. So, is possible to use the port.
Regards.
