Hello ,
I have notice that on the board
in the SPI CS# Config box , there is a pin 23 called “GPIO14”
how can I use it ?
can program it to send “0""1” on demand?
Thanks,
Hello ,
how can I use it ?
Thanks,
one of RouterOS give a way by CLI only.
They are few post at forum.
Search that !
I have found this
http://forum.mikrotik.com/t/rbm33g-has-6-gpio/143953/1
but it only wrok for pin3
when I run this commands
/system gpio set pin3 direction=output output=0
and chgeck voltage on pin3 - I get 33mV witch is OK
when I run this
/system gpio set pin3 direction=output output=1
I get 3.297V which is OK
but when I try to run it on pin15 - I get 0 all the time
any idea why ?
also mayeb I need to change something in the jumper3 GPIO J23 ?
Thanks ,
support@mikrotik.com
mikrotik.com/support
only that way.
