This is a simple question. I am not very clear on what I am reading.
Can I use 2 minipice WiFi boards and a LTE M.2 card together at the same time?,
See this document https://help.mikrotik.com/docs/display/UM/RBM33G
- Insert the miniPCIe and M.2 cards (not included) and secure them with the included screws. [Only one 802.11 wireless card can be used at once]. It is suggested to use the other slot for LTE modems. Please see MiniPCIe slot usage paragraph.
Read about USB jumper.
Are you here from OneMarcFifty video?
Best choose LtAP that includes Wi-Fi on board.
I have both devices but I not have minipcie wifi cards.
Regards.
Thanks, buckeye and krafg for your responses. I will check them out, I will also check out the LtAP
