RBmAP2n doesn't boot with ethernet cable plugged in
Hello
I own an RBmAP2n but have some trouble with. RouterOS V6.38.3 and RouterBoard firmware V3.24. Device is in router mode.
The device doesn’t boot with WAN ethernet cable plugged in, but hangs with ETH1, ETH2, WiFi, PWR LED’s on. No connection will be established. I can pull out the cable, nothing happens, all LEDs are illuminated as before, the device doesn’t respond. If I power on the device without cable connected, the device boot up. After a few seconds the device go behind the state I described before, and ended up with PWR LED on, all other LEDs off (I don’t use wifi). I then plug in the cable, ETH1 LED lights up and connection are established instantly. On the WAN side the device (should) get its ip adress by DHCP.
Are there any hints what’s happen?
Are there anyone out there with a hint for me? Problem persists, can’t believe I’m alone. :wink:
I think I can give more information if you ask me the right things.
Don’t want struck the device to garbage. :frowning:
