Is there anyway to disable the reset button on side of RBmAP2n to prevent end users from ‘easily’ erasing settings?
Did you try this? :
/system routerboard settings> set enable-jumper-reset=no
http://i.mt.lv/routerboard/files/mAP-140908144858.pdf
The MAP has a reset button on side of unit that is too tempting for someone to push which I would like to disable. It also has a pin hole on bottom of unit with access to jumper hole which I would like to leave enabled in case someone must reset it some day.
I expect that the pin hole and the switch are on the same wires. If so you cannot disable one and leave working the other. If the switch is on the end of the wire you can find a link on pcb and cut it. This would disable the switch and leave the pin hole working.
that settings does nothing to reset hole functionality.
Just disable button leaving reset-hole working
Better than my expectations.
Perfect. Thanks.
