Does the RBmAP2n support WPA3? I have the latest stable routerOS installed (6.49.7).
Only WPA and WPA 2 can be selected in the Security profile.
Does the hardware of the RBmAP2n support WPA3 in principle, can this be added by software?
I think it was introduced in the Wave2 driver, can’t find any reference in the help files with the standard driver:
https://help.mikrotik.com/docs/display/ROS/Wireless+Interface
To my knowledge, no.
Map can not use wifiwave2 driver.
Additionally, IF the HW would support that driver (which it doesn’t), you’d be required to move to ROS7.
