Hello
I have already followed the guides in the wiki, but I can not activate the serial on this routerboard
It just seems that routerOS can not use the serial port, did I forget something?
Or is this model physically disabled?
Thanks in advance !!
Hello
AFAIK this model doesn’t have serial port, and USB port is for powering only. What is your goal?
It’s on the pcb like the previous RBmAP2n model
I’m testing compatibility with Openwrt / LEDE, but without running serial port is very difficult …
thanks again
This device does not have a serial port. If you will solder connectors for serial header on device it still will not work.
ok , I understood
thank you
