RBSXT with Huawei EC167 CDMA EVDO modem works perfectly
Local provider, namely AHA (www.aha.co.id) in Indonesia provide Internet Access by using this Huawei EC167 modem
EVDO 3.1Mbps max data throughput.
I tried on RBSXT, it works :slight_smile:)
So, RBSXT have backup connection link using CDMA EVDO.
he he he he ..
  • Rio.Martin -
This one? http://modem-techno.blogspot.com/2010/07/huawei-ec-167-cdma-usb-modem-2000-1x.html
did it fit inside the SXT just fine? perfect! thanks for sharing
Yup, thats the modem i meant.
Future plan, i will test it to combine their cell network and my 802.11n network .. :stuck_out_tongue:
Modem should be placed outside with small hole at the right side of the SXT door should be punch for USB cable to fit.
This would be great.
My future test:
  1. Gigabit USB Ethernet
  2. USB Hub to connect 3 - 5 modems in one USB port
he he he he, its so interesting to put this little wireless called SXT on lab .. :slight_smile:
I can not use the EC167 in my mikrotik system (x86). Every time I plug the modem, always Invalid.
Will you teach me how to install the EC167 in mikrotik x86 system?
btw, I use RouterOS v3.30
Thank’s
dude, do you have config for this setting?, btw I also using AHA. I still didn’t get what the meaning of modem-init and my ppp-client still dialing-out w/o success
