RBSXTR VLAN
Hello All,
I have configured my RBSXTR with LTE Passthrough as per the wiki. My main router is RB3011. Could anyone explain how to set up a management vlan between the two as per below taken form the wiki I am using ether1 on both devices.
It is suggested to create additional connection from the LTE router to the host for configuration purposes. For example vlan interface between the LTE router and host.
https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Passthrough_Example
Hi!
I would like to know exactly the same thing. The wiki is a little vague for not so experienced users.
If someone would share a configuration with us it would be greatly appreciated.
Still trying to figure this out, should the LTE interface passtrough to a vlan interface also?
In the mean time I’ve set up RoMon on both devices which allows me access for anyone else stuck with the vlan like myself.
Anyone any ideas?
To answer my own question
Its a good idea to set up RoMON before starting.
**SXTLTE** Configure 2 VLANs on ether 1 (vlanLTE - 100, vlanMGT - 99) Assign vlanMGT an IP address something from the main router subnet. Switch menu add VLAN 100 to ether1 and CPU (Not sure if CPU is necessary) and do the same for VLAN 99 Switch menu Port ether1 - VLAN Mode Secure, Leave as is, Default VLAN ID 99 Set LTE APN to Passthrough vlanLTE Interface list add vlanLTE to WAN IP Routes - add your Gateway here
MAIN ROUTER
Add vlanMGT to Bridge
This works for me I can reach SXTLTE from the IP address. any suggestions for improvements are welcome.
