RBwAPG-5HacD2HnD wap new AC bootlooping after changing WLAN2 settings
I have 3 waps. I’ve been trying to get a pair working together in a ap bridge, station bridge config for a wifi bridge on 5ghz.
I’ve been having problems with the bootlooping after changing WLAN2 settings. I boot them up with default settings, change the settings on wlan2, connect wifi, get everything working and as soon as I powercycle them they BOTH start boot looping. One of the waps is unrecoverable with netinstall after the fact but I have been able to recover the other two reliably.
It happens on both the AP bridge and station bridge simultaneously and it didn’t seem to matter if I had 6.47.9, 6.48.1 or the firmware they were shipped with(which I don’t remember what version it was)
I have country set to united states3 to skip the radar detection.
I appreciate any help!
Edit: it seems to have happened when I set the wireless protocol of wlan2 to NV2 NSTREME 802.11 on both routers. Don’t know if it’s the cause
Edit2: seems to happen also if I set wireless protocol to nv2
Arnthor
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[admin@MikroTik] > export
# jan/02/1970 00:03:40 by RouterOS 6.47.9
# software id = ZW30-YQ88
# model = RBwAPG-5HacD2HnD
# serial number =
add admin-mac= auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=outdoor mode=\
    ap-bridge ssid=MikroTik-473A5C wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-eeeC \
    country="united states3" disabled=no distance=indoors frequency=5240 \
    installation=indoor mode=station-bridge ssid=MikroTik-473A5D tx-power=-10 \
    tx-power-mode=all-rates-fixed wireless-protocol=nv2-nstreme-802.11
/interface wireless nstreme
set wlan2 enable-nstreme=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
    connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
I only want to set it to NV2 because I found that the speed I’m getting on 802.11 and Nstreme is 1/3 of what I can get with NV2
