RBwAPG-60ad Slow speed
Helllo guys,
Since recently I’ve noticed some problems with PtP link of two RBwAPG-60ad (came in a kit, preconfigured). The link is between two buildings used for internet access and data transfer. Thing is that in tests (NetCPS or Iperf) and SMB data transfer is achieving around 485 mbps. When I run bandwidth test between two RBwAPG-60ad using TCP it shows around 1800 mbps in one direction or around 900 in both. I’ve also run bandwidth test from computers on both sides to corresponding RBwAPG-60ad and the one on the other side using MikroTik btest. In these tests average bandwidth is around 930-950 mbps. Both units are on factory settings with an exception of changing the IP address and login password. I’ve tried downgrading the firmware since I thought some software update broke it, but no luck. Any suggestions what should I try?
Best regards,
Alex
