RBwAPG-60ad wireless wire troubleshooting
This kit is setup at a remote client site and the devices worked out of the box to connect two switches to each other wirelessly. After some time, the connection began having intermittent issues that would seemingly correct themselves after a short time until recently the connection has failed and is not able to reconnect on its own. I have to the best of my ability ruled out connection issues on either side of the MikroTik devices. I am able to connect to both the master and the slave via Winbox, and have updated the firmware on both to the latest version 6.44.3, as well as reset both devices to their default configurations. This process has not been able to restore the connection between the devices. I am wondering if there are any troubleshooting guides or things I can try to diagnose the connection issue. Thank you.
could you please post configuration from both sides of the link?
please paste output from:
/interface w60g export hide-sensitive
