RBwAPG-60adkit and QMP The quickMOUNT
Hi guys, could someone confirm if the QMP The quickMOUNT https://mikrotik.com/product/QMP is compatible with RBwAPG-60 https://mikrotik.com/product/wireless_wire ?
looking at the pictures I am not sure how to fix ti.
thanks
BR
Iggy
It is not compatible
it is compatible, there is “tube” attachment included
https://cdn.mikrotik.com/web-assets/rb_images/1445_hi_res.png
Which is not listed in the brochure, let alone on the dimensions drawing …
https://cdn.mikrotik.com/web-assets/product_files/quickMount_pro_190516.pdf
https://cdn.mikrotik.com/web-assets/product_files/QMPdimensions_221150.pdf
Thanks for pointing this out - it will be fixed.
Good. :slight_smile:
Should be fixed now
The new pdf’s are here (just in case one clicks on the previous links I posted):
https://cdn.mikrotik.com/web-assets/product_files/quickMount_pro_250318.pdf
https://cdn.mikrotik.com/web-assets/product_files/QMP-ASSY_250414.pdf
:slight_smile:
