I am concidering running 3 pairs of RBwAPG-60adkit to connect some buildings, but i cannot find anything conclusive regarding these units in an outdoor climate. I find that in the brocure they say that they can be mast mounted, but thats the only reference i can find.
They will be mounted outdoors in norway, and we see harsh winters and heavy rain.
Yes, you can use them outdoors in cold northern Norway. Just make sure to mount the unit with cable pointing downwards, since some water could seep into the case next to the cable opening, depends on how you close it’s lid.
