RBwAPG-60adkit ROS6 or ROS7?
does someone have experience with RBwAPG-60adkit performance and good or bad behavior with ROS 6 and ROS 7?
Should I stick to 6 or upgrade to 7?
once I install RBwAPG-60adkit on the top of the buildings I have no wishes to go on the roof again to change ROS upgrade or downgrade.
upgrade to 7.10 there is bix fix for 60Ghz. Do not use on those devices ROS6 many bugs…
If you make sure your ethernet cable is accessible from downstairs, there is no need to climb up or down.
