RBwAPR-2nD&R11e-LTE need help
I bought the RBwAPR-2nD&R11e-LTE kit but the R11e LTE pci card is not on the interface list.
I upgraded the firmware and RouterOS but nothing helps. Also the R11e card gets very hot, almost too hot to touch, is that normal?
Any advice would be appreciated
check what “/sys resource usb print detail” shows.
you should see something like this:
[admin@router3] > /system reso usb print detail
 0 device="1:1" vendor="Linux 3.3.5 ehci_hcd" name="RB400 EHCI" serial-number="rb400_usb" vendor-id="0x1d6b" device-id="0x0002" speed="480 Mbps" ports=1
   usb-version="2.00"
 1 device="1:2" vendor="MikroTik" name="R11e-LTE" serial-number="000000000000" vendor-id="0x2cd2" device-id="0x0001" speed="480 Mbps" ports=0 usb-version="2.00"
if you already opened the device, try to unscrew and reseat the modem.
if you still have problem getting the LTE interface to recognize, please report to support@mikrotik.com with a support output file.
