RBwAPR-2nd WAN port option
We bought new RBwAPR-2nd lte and wanted to know is the available physical port can be used as Gigawan port behind internet modems or not?
لا
Didn’t you check BEFORE you bought it?
Not my job, why so lazy?
https://mikrotik.com/product/wap_lte_kit, scroll down to ethernet, although you might run into lactic acid before you get that far. :stuck_out_tongue_winking_eye:
It was mainly required only as lte but we came across a need to use it as different option.
Thanks.
