rbwsAP-5hac2nd discontinued
Hello good morning.
The rbwsAP-5hac2nd that was quite successful and well fitting in Hospitality projects is discontinued unfortunately.!!! :frowning: :frowning: :frowning:
Do we know if there are any plans for a successor model that will satisfy in room WiFi coverage comfort and keep interior architects happy at the same time?
Better ask sales or your distributor.
If something is in the works, they should know.
hi, this is quite important topic…
is there an alternative for replacement ??
can be any other mikrotiks unit deployed on wall with electrical-box mount design ?
Hi, any update ? I would really appreciate some device, ideally with the same form factor but with AX wireless and (at least ) 1Gbps eth ports.
The newish Wap Ax may be suitable, without the base/support it can be wall mounted and it is small enough to be unobtrusive:
http://forum.mikrotik.com/t/wap-ax/167172/1
https://www.wifihw.cz/img.asp?attid=3848208
yeah, I am using wap ax right now. With small modification can be mounted on standard electrical in wall box (just drilled two holes) but in some cases I am 1 eth port short / agains old wsap unit which has 3 eth ports
