I only have 5212 (CM6 AG) in my router at home.
The compression tab was there when I first went to winbox.
Then after changing a few other settings, the tab vanished.
Closing the “wireless” interface frame in winbox, and re-opening, it came back.
Small bug, or not?
That is ALSO what I have found.
Sometimes on opening winbox the compression tab is there, sometimes NOT !!
And winbox crashed on me as well, first time ever..
Activating compression on this link 5212 to 5213 drastically SLOWS traffic from 40 to 10 MBits/s. It is a test link of an amazingly long 50 metres … but the fact remains, compression does not speed things up
Unless of course compression is not supported in the 5213??
I will stick with nstreme and 5.8 G turbo for now..
HI Stephen,
On 2.9rc10 is present a big bug. I think because driver is updated with hardware compression.
In fact don’t work properly 5Ghz-turbo and Nstreme, instead Nstreme2 crash after 2 minutes of traffic.
Compression should be on the Advanced tab, after preamble - if it is there..
As I say above - and so does stevenpatrick - it seems to appear and dissappear..
However - IMO don’t bother with it yet - I have a short test link, and using compression my speed dropped from 45 MBits/s or so to 10 MBits/s …
SO I don’t think it is quite right yet )
I found compression settings. It wasn’t installed on my latest 2.9rc10, since it appears the wireless-legacy was installed by default (even though I uploaded both packages via FTP, it upgraded to legacy instead of the normal wireless package by default).
I had the same problem with routing. Instead of the normal routing package, it installed routing-test. So now I’m gonna have to be more careful about what I select.
Also, on compression, I’m seeing the same as you. My 50-60Mbit links were flying before, turn on compression and we’re down to about 10Mbit or less.
