when i upgraded today i tryed to get this part to work, it was flawless on the 2.8 OS, on 2.9 it brings up the simple queue like it should but it dos not have any settings in it at all for the limits or the burst time…
is anything supposed to be different or and i over looking somthing…
everything else is as it should be…
[admin@MikroTik] queue simple> print
0 D name="<hs-Local>" dst-address=0.0.0.0/0 interface=Local parent=none
priority=8 queue=hotspot-default/hotspot-default limit-at=0/0
max-limit=0/0 total-queue=default
i would like to get this sorted, i use radiator for the radius server and i down graded back to 2.8 just to check and see and it definitly works, go back to 2.9 and this happens..
Hello, if you dont see queues its because MT server is not able to understand the radius reply attributes. Look at the latest manual on this issue or try this format on your radius reply attributes: Rate-Limit=“36k/56k 128k 36k/56k 10/10”
it is not by hotspot as hotspot is not enabled at all.
when i make a pppoe connection that is what comes up but when i use 2.8 software it comes up proporly with a name of (the xxx = the username given)
i had to go back to 2.8 yesterday because of this, also you said it was the hotspot doing it, i reuploaded the 2.9 software and tryed to setup hotspot and it did not work proporly.
if you leve the hotspot directory blank everything works greate, but if you choose the hotspot directory it dos not work at all, you see that page but the page is useless, when you click login it puts you back to the same page, and from the begining you can see veriables as text on the page wich should not be there…
ok i formated the drive, i do not know why but it seems that there was stuff left over from 2.8 that it did not like at all, because now everything seems to be running, the hotspot as i said before and the pppoe rate limit is now working also…
dont know if it was somthing i goffed, it might be a newbie mistake, but it might be worth noting for people that have done the upgrade and have seen strange things happen that other have not…
