RC11 very bad wireless
Always lost the wireless connection on high traffic lines !!! Very, very unstable the 3.xx series !!! Unusable system !!! :imp: :imp: :imp: :imp:
We have never had V3 wireless work correctly. We installed RB333 w/RC6-10 and it always had packet loss. Replaced with RB532, same radios, pigtail and antenna and everything works fine. We’ve given up in V3.
We have RC10 running, 35meg both ways, nstream-dual, dual links, total of 42 miles. No issues that we can find so far..
Have run now beta on all my routerbords and ap a while.
All working great, ofc som problem here and there but find always a soulosion.
and remember its e beta. be for i did jus avaya wirless systems.
And the mikrotik systemts it 10 times more stable, and more control.
You can do what you want.
Aboute te timeoutes try and change you config.
I did use 1 moth to finde out the best conf to 333
and even more on my ap. evrey day i just change a littel thing.
and run som tests.
I don’t know what is a problem but very aggravate this. Maybe some hardware problem ? But before upgrade never lost the connect. If the bridge side disable/enable interface after go again. On high traffic line (5gzh-turbo, nstreme) .
Now write some scrypt…I remeber long time ago when developed early 2.9 version have this problem. After sole it.
I to nose for hardware maybe some component on same routers.
The config asrosk/asus board celeron 3ghz. I don’t like asrock/asus p5pevm…
FYI
It is a release candidate and NOT a beta.
Have you had random reboots? We have RB333 RC10 running with Nstreme-dual, 40MHz channels on each end, separation of 500MHz, separate antennas, all the good stuff.
The far end has both an Nstreme Dual link and a single N-streme point to point feeding off of it. It seems to reboot at least once every two days.
We’re not the only one with this issue. Before I set up a watchdog requiring reboot if pings across the Nstreme dual link fail, the box would hang!!! (Suspected kernel panic)
i have very bad performance issue on Nstream dual on 333.
I changed everything from antenna to pigtails, including the radio cards, but nothing changes the bad performance.
My link is 10km and the signaal are about -59/-60, when i start to have traffic, the rates go crazy from 9mbps up tp 36mbps, with no traffic thery are at 54mbps.
Ros
We noticed a problem in wireless communication on our main 5GHz AP few days ago, but we were not sure if it was because of the upgrade from 2.9 to 3.0RC11 or weather conditions (fog and some snow).
Hardware: PC Compaq 800MHz, Ubiquiti SR5 - HyperLink 12dB omni antenna, two more 5GHz cards connected to grid antennas.
We connect to this SR5 several base stations without heavy traffic and two more with point-to-point links using other two cards. Totally 7 x 3.0RC11 stations, 3 x 2.9.x stations and one Ovislink 5GHz client bridge are usually connected to this SR5.
Pings were huge with 3.0RC11, up to 1s and with some losses also, maybe up to 10%.
I finally decided to try 2.9.50 and it worked. With approximately the same traffic, pings were normal, up to maybe 14ms and mainly 1-2ms. Other two cards with point-to-point nstreme links worked correctly, just this ap-bridge was the problem. So, there is still something with 3.0RC11 wireless.
Well done. The problem exactly. No hardware. When use RC9 on two router - nothing problem. Morning upgrade to RC11 - some hours and now disconnect. Disab/enable bridge side and work again. This palce where come this problem continiusly high traffic - over 10 mb up/down, nstrem, 5g turbo. And other, if switch off the adaptive new feature, better the ping and stable the connect. Not perfect, but better.
This is a software bug.
And the 2.4 AP too not correct. More disconnect and slowly - or must restart client -connect after upgrade.
most of you got problems after upgrading from v2.9 to v3.0 because you are using Ubiquity High power cards and most probably you had changed the tx-power. In version 3.0 we are showing correct tx-power info for most of the Ubiquity cards. Here for example is the output from the XR2 card:
v2.9:
    current-tx-powers: 1Mbps:18,2Mbps:18,5.5Mbps:18,11Mbps:18,6Mbps:18,
                       9Mbps:18,12Mbps:18,18Mbps:18,24Mbps:18,36Mbps:16,
                       48Mbps:14,54Mbps:13
v3.0:
      current-tx-powers: 1Mbps:28(18),2Mbps:28(18),5.5Mbps:28(18),11Mbps:28(18),
                         6Mbps:28(18),9Mbps:28(18),12Mbps:28(18),18Mbps:28(18),
                         24Mbps:28(18),36Mbps:26(16),48Mbps:24(14),54Mbps:23(13)
The number in the brackets represents the value from the eeprom. In v2.9 you were changing this eeprom value, but in v3.0 you are changing the real value that it outside the brackets. We always suggest to use the default tx-power-mode, as then you would not run into such issues.
All my cards are at default tx-power value except one CM9 which is at card-rates 30 and is used for link. It seems to be true that this happends at high-power cards, I had problems mainly at three points, one XR5, one XR2, but one CM9 also. I downgraded all routers to 2.9.50.
I don’t recommend you to use CM9 card at 30 - it will not work very long, it could burn down and also the performance could be bad.
It is working like this over one year :slight_smile:
It looked broken, so I put more tx-power and it worked. If it burns out, I will just throw it away, I already don’t count on it.
Completely useless entry!
There are around 50 adjustable option for wireless in RouterOS, i will repeat myself - FIFTY. That is a lot of thing that you can play with. There are no other product in the market that gives so much options to the customer. Ether customer will be able to use them or not it is other question.
Version 2.9 and 3.0 have different sets of those options, so you can’t just upgrade and compare - it is necessary to adjust the setup.
Comon guys, we should be network specialists here - instead of this nonsense it is much more better to write topic this way:
1) Wireless link description:
<hardware decription, distance, landscape>
2)My configuration in ROS v2.9 was:
<list of options>
2)Performence in ROS v2.9 was:
<throughputs, latency, signal level, CCQ etc.  >
3) performance and problems after upgrade:
Can somebody, please, suggest me how to get at least v2.9 performance back
Thanks,
I suggest, open another topic and there use academic/theoretic method. We haven’t time follow this.
Maybe, somebody write the cool thing about. That is the forum essential. This is the real word area.
Before write something here, change more mail by support and spend many hours by new versions.
Regards
what’s essential? that you say “bad wireless, not work” and we understand what you mean? sorry, doesn’t work for me :slight_smile:
Ok, “blt”, lets play it your way in that case my answer to you original post:
would be:
Useless! Isn’t it? Sorry, but topic like this can be easily created by 10-year old.
Next time add some REAL information in your topic so we can compare it to our setups and suggest you something.
I expected if I upgrade 2.9 machine to 3.0 that everything will still work. I had major problem with our central machine with just one Ubiquiti SR5 card with all default settings, no hotspot, connection tracking turned off, no firewall rules, very simple settings. If I upgrade this machine to 3.0, I don’t expect problems, but I was wrong. I tried to change many parameters, but it didn’t help. Other frequences didn’t help either. Then I moved to 2.9.50, put all back to default and it worked fine and it is still working fine. I can’t give you more prove, but I will stick with 2.9.50 for some time.
I have another machine with 3.0RC11 which does some nstreme link with disabled CSMA and this one is working good, I can’t complain.
I have the random reboots with RB333 too. The only positive thing is the fast boot after the watchdog reset the board.
