After upgrading to rc2 from rc1, wireless band frequency will not keep its 2.4 b/g setting, jumps back to 5mhz and disables. After reboot settings stick for about and hour then jumps back.
here are the default settings upon reboot:
[admin@MT] interface wireless> print
0 X name=“wlan1” mtu=1500 mac-address=00:02:6F:20:F4:33 arp=enabled disable-running-check=no interface-type=Atheros AR5212 radio-name=“00026F20F433”
mode=station ssid=“MT” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default
rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps
basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power=default tx-power-mode=default
noise-floor-threshold=default periodic-calibration=default burst-time=disabled fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both
p.s. when settings jump to 802.11a, and changes made give this error:
scan-list does not include any supported channel
Only way to make changes is to reboot and do right there.
