I just upgraded to RC3 and I can’t get to the web page on this version either, same as RC2.
I have some graphics still show “Loading” I tried the work around posted in missing graphics thread but that didn’t work.
The graphic is showing on mine but not some other login…
If copy and paste of a device with a link, you must delete the link and recreate it to have it update which interface it is connected to, you can’t just select a different interface. I documented this in the RC2 thread. There are other issues with copied devices…
I set a map to fit and I have tired many times to set it back to 100% and it just won’t stay it keeps using fit even though I have clicked ok, apply or hit Enter. Instead setting it to 10% then to 100% the setting might have been saved this time…
The button for apply rarely applies the setting. Many times when clicking apply the setting reverts back to it’s previous setting. Hitting enter instead of pressing ok or apply usually works. Clicking on ok usually saves the setting also but not every time.
Adding a note and clicking on apply then ok still puts the date of Dec/31/1969. Easily worked around just use ok.
SD
