RC3 is coming....
[demo@demo.mt.lv] > /interface wireless monitor wlan1-uplink
status: connected-to-ess
band: 5ghz
frequency: 5600
tx-rate: 36Mbps
rx-rate: 36Mbps
ssid: flatant
bssid: 02:00:00:AA:00:00
radio-name: 000C420506F3
signal-strength: -72
tx-ccq: 24
rx-ccq: 28
current-ack-timeout: 28
current-distance: 28
wds-link: no
nstreme: no
framing-mode: none
routeros-version: 2.9rc3
last-ip: 159.148.60.20
[demo@demo.mt.lv] >
Yes, you are right! :wink: It will be on the web in few hours.
There will be a fix for a wireless, that hopefully will fix the issues with the wireless interface that was loosing configuration.
Downloading it now …
I got a copy this morning…
I went to work and it seems to be pulled…
RC2 seems to be latest avail..
Sould I delete it?
Are there issues? :confused:
Craig
still no RC3 for download :frowning:
Well, I got it, and installed it on 3 routers at the office.
It works fine in wireless bridged mode with 72Mbps+ of actual traffic throughput, Nstreme, 5GHz Turbo mode, soak tested for 3-4 hours this afternoon.
I guess there must be problems with it somewhere if they pulled it…
Regards
Theres a post at the top of the download page that states RC3 had a major problem and it was yanked, and that RC4 will be out shortly. Easy to miss because its in the same font / text as everything else… shows you how much we all look at things half blindly.
Sam
Well me too - didn’t notice the post - and fortunately my routers are test routers, no live traffic … looking forward to RC4 (tomorrow they promise) …
OOPS..
I did not see it eather… :smiley:
Will look forward to RC4
Craig
did they mean today as in may 19, usa time or the 20th cause its the 20th there so where is it :slight_smile:
in a few hours from now. in rc3 there was a probem with RouterBOARD 500 version, so the other version works fine. but you should better wait for the corrected release.
Still no RC4 ? … i need it :slight_smile: my wlan disconects , i have sent the file again.
richard
go back to rc2 works fine
Randy
No RC2 do the same thing for me the wlan card is ther but cant conect to the clients… but if i enabel and disabled the card works fine.
I think it will be out today.
