rc4 bug???
hello all
ok this is strange. i cannot access the router from its outside ip nor its inside ip or mac
cannot telnet either
but i can from withing another MT mac-telnet to it works . so i removed all firewall rules still nothing any suggestions.
Randy
it works fine Nat vpn etc.
the only reason i noticed it was tried to add a user. no go.
why do you think it is a bug? don’t you think somebody would have noticed such a great problem? i think you should carefully go through your configuration
normis
maybe i should of stated that this is only on one router that is a rb500 board dont know why .what should i look for .
in the config or the rules
Randy
check if your hotspot is not enabled. also to see all filter rules, type:
ip firewall filter print all
