Downloaded and running on a home AP, works fine as far as I can see -
Regards
Regards
For all of you out there that use LCDs on your routers for stratus at a glance…
You will see that after upgrading using the X86 single .NPK file your LCD will be blank… ![]()
All is not lost… ![]()
Simply download the ALL-Packages file, decompres it and upload the LCD.NPK file to the router. (REMEMBER TO USE BIN format !!!)
Reboot the router and your LCD will again be a happy camper… ![]()
Craig
