It doesn’t work too.
I’ll precise my configuration:
192.168.1.121-[ether1-point-A] ====(nstreme2)====[point-B-ether1]-192.168.1.120
I want to create bridge, transparent connection.
configuration on Point-A:
[admin@point-A] > ip address print
# ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.1.121/24 192.168.1.0 192.168.1.255 ether1
[admin@point-A] > /interface wireless print
0 name="odbior" mtu=1500 mac-address=00:14:85:CA:59:A1 arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave
ssid="MikroTik" frequency=5180 band=5ghz scan-list=default antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none
wds-ignore-ssid=no default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
1 name="nadawanie" mtu=1500 mac-address=00:0B:6B:09:A0:1F arp=enabled interface-type=Atheros AR5213 mode=nstreme-dual-slave
[admin@point-A] > /interface wireless nstreme-dual print
0 R name="dual-AB" mtu=1500 mac-address=00:14:85:CA:59:A1 arp=enabled disable-running-check=no tx-radio=nadawanie rx-radio=odbior
remote-mac=00:16:E6:34:D7:1E tx-band=5ghz tx-frequency=5320 rx-band=5ghz rx-frequency=5180 disable-csma=no
rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps ht-rates=1,2,3,4,5,6,7,8
ht-guard-interval=long ht-channel-width=20mhz ht-streams=single framer-policy=none framer-limit=2560
[admin@point-A] > /interface bridge print
0 R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:1D:37:62 protocol-mode=none priority=0x8000 auto-mac=yes
admin-mac=00:00:00:00:00:00 max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
[admin@point-A] > /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic
# INTERFACE BRIDGE PRIORITY PATH-COST
0 ether1 bridge1 0x80 10
1 dual-AB bridge1 0x80 10
configuration on Point-B:
[admin@point-B] > /ip address print
0 192.168.1.120/24 192.168.1.0 192.168.1.255 ether1
[admin@point-B] > interface wireless print
0 name="nadawanie" mtu=1500 mac-address=00:0C:42:1B:1D:AC arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave
1 name="odbior" mtu=1500 mac-address=00:16:E6:34:D7:1E arp=enabled interface-type=Atheros AR5413 mode=nstreme-dual-slave
[admin@point-B] > interface wireless nstreme-dual print
0 R name="dual-BA" mtu=1500 mac-address=00:16:E6:34:D7:1E arp=enabled disable-running-check=no tx-radio=nadawanie rx-radio=odbior
remote-mac=00:14:85:CA:59:A1 tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5320 disable-csma=no
[admin@point-B] > interface bridge print
0 R name="bridge1" mtu=1500 arp=enabled mac-address=00:0C:42:1C:B0:2D protocol-mode=none priority=0x8000 auto-mac=yes
[admin@point-B] > interface bridge port print
1 dual-BA bridge1 0x80 10
connection on nstreme2 is working fine:
[admin@point-B] /interface wireless nstreme-dual> monitor 0
rx-signal-strength: -64dBm
tx-signal-strength: -54dBm
rx-rate: "54Mbps"
tx-rate: "54Mbps"
connected: yes
packets: 149,170
bytes: 24408,19759
frames: 330,347
frame-bytes: 37906,33979
hw-frames: 671,665
hw-frame-bytes: 51694,46699
tx-retries-timeout: 11
tx-retries-lost: 0
rx-bad-seqs: 0
rx-duplicates: 1
Connection is working but there is no transmision between bridges.
Please help, it’s very urgent for me.
