I have an IPSEC site-to-site tunnel beetween my mikrotik RB2011UiAS and my clients router (ZYXEL). Both phases are fine, the connection is established and I can see packets on my firewall going through accept rules. However they have to use RDP to one of my MS-Windows Server 2003 machines, but cannot connect to it neither ping the machine.
My WAN: xx.xx.xx.146
My gateway: xx.xx.xx.145
MY LAN: 10.0.0.0/24
Their WAN: xx.xx.xx.38
Their LAN: 192.168.2.0/24
Address configuration
address print
# ADDRESS NETWORK INTERFACE
0 ;;; LAN-IP
10.0.0.1/24 10.0.0.0 bridgeLocal
1 ;;; WAN-IP (01)
xx.xx.xx.146/29 xx.xx.xx.144 WAN1-ether10
IPSEC related things
ipsec peer print
Flags: X - disabled, D - dynamic
0 ;;; Phase 1: KartGis
address=xx.xx.xx.38/32 local-address=:: passive=no port=500
auth-method=pre-shared-key secret="****" generate-policy=no
policy-template-group=default exchange-mode=main send-initial-contact=yes
nat-traversal=yes proposal-check=obey hash-algorithm=sha1
enc-algorithm=aes-256 dh-group=modp1536 lifetime=8h lifebytes=0
dpd-interval=2m dpd-maximum-failures=5
ipsec proposal print
Flags: X - disabled, * - default
1 name="kartgis" auth-algorithms=sha1 enc-algorithms=aes-256-cbc lifetime=1h
pfs-group=modp1536
ipsec policy print
1 ;;; KartGis VPN
src-address=10.0.0.0/24 src-port=any dst-address=192.168.2.0/24
dst-port=any protocol=all action=encrypt level=require
ipsec-protocols=esp tunnel=yes sa-src-address=xx.xx.xx.146
sa-dst-address=xx.xxx.xx.38 proposal=kartgis priority=0
Routes related things
route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S ;;; Gateway 01
0.0.0.0/0 xx.xx.xx.145 1
1 ADC 10.0.0.0/24 10.0.0.1 bridgeLocal 0
2 ADC xx.xx.xx.144/29 xx.xx.xx.146 WAN1-ether10 0
NAT related things
firewall nat print
0 ;;; KartGis IPSEC Tunnel
chain=srcnet action=accept src-address=10.0.0.0/24 dst-address=192.168.2.0/24 log=no log-prefix=""
1 ;;; Internet 01
chain=srcnat action=masquerade src-address=10.0.0.0/24 out-interface=WAN1-ether10 log=no log-prefix=""
Firewall rules
firewall filter print
0 ;;; IPsec
chain=input action=accept protocol=udp dst-port=500
1 chain=input action=accept protocol=ipsec-esp
2 chain=forward action=accept connection-state=established,related src-address=192.168.2.0/24 dst-address=10.0.0.0/24 log=no log-prefix=""
3 chain=forward action=accept connection-state=established,related src-address=10.0.0.0/24 dst-address=192.168.2.0/24 log=no log-prefix=""
4 ;;; Accept established and related packets
chain=input action=accept connection-state=established,related
5 ;;; Accept all connections from local network
chain=input action=accept in-interface=bridgeLocal
6 ;;; Drop all packets from blacklisted addresses
chain=input action=drop src-address-list=Hackers in-interface=WAN1-ether10 log=no log-prefix=""
7 ;;; Drop invalid packets
chain=input action=drop connection-state=invalid log=no log-prefix=""
8 ;;; Drop all packets which are not destined to routes IP address
chain=input action=drop dst-address-type=!local log=no log-prefix=""
9 ;;; Drop all packets which does not have unicast source IP address
chain=input action=drop src-address-type=!unicast log=no log-prefix=""
10 ;;; Drop all packets from public internet which should not exist in public network
chain=input action=drop src-address-list=NotPublic in-interface=WAN1-ether10 log=no log-prefix=""
11 ;;; Accept established and related packets
12 ;;; Accept forward packets from natted connection
chain=forward action=accept connection-state=established,related connection-nat-state=dstnat in-interface=WAN1-ether10 log=no log-prefix=""
13 ;;; Drop invalid packets
chain=forward action=drop connection-state=invalid log=no log-prefix=""
14 ;;; Drop new connections from internet which are not dst-natted
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=WAN1-ether10 log=no log-prefix=""
15 ;;; Drop all packets from public internet which should not exist in public network
chain=forward action=drop src-address-list=NotPublic in-interface=WAN1-ether10 log=no log-prefix=""
16 ;;; Drop all packets from local network to internet which should not exist in public network
chain=forward action=drop dst-address-list=NotPublic in-interface=bridgeLocal log=no log-prefix=""
17 ;;; Drop all packets in local network which does not have local network address
chain=forward action=drop src-address=!10.0.0.0/24 in-interface=bridgeLocal log=no log-prefix=""
18 ;;; No internet but ESET
chain=forward action=drop src-address-list=nointernet dst-address-list=!eset out-interface=WAN1-ether10 log=no log-prefix="
NotPublic List
/ip firewall address-list> print
# LIST ADDRESS TIMEOUT
1 NotPublic 0.0.0.0/8
2 NotPublic 10.0.0.0/8
3 NotPublic 100.64.0.0/10
4 NotPublic 127.0.0.0/8
5 NotPublic 169.254.0.0/16
6 NotPublic 172.16.0.0/12
7 NotPublic 192.0.0.0/24
8 NotPublic 192.0.2.0/24
9 NotPublic 192.168.0.0/23
10 NotPublic 192.88.99.0/24
11 NotPublic 198.18.0.0/15
12 NotPublic 198.51.100.0/24
13 NotPublic 203.0.113.0/24
14 NotPublic 224.0.0.0/4
15 NotPublic 240.0.0.0/4
48 NotPublic 192.168.3.0/24
49 NotPublic 192.168.4.0/22
50 NotPublic 192.168.8.0/21
51 NotPublic 192.168.16.0/20
52 NotPublic 192.168.32.0/19
What am I missing here or have too much that ping and RDP do not work over the tunnel? Help!
EDIT
Got the ping to work, by changing this rule:
to this
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=WAN1-ether10 packet-mark=!vpn log=no log-prefix=""
Still RDP is not working.
