The strategy is:
Two site with 2 MT device(hap ac2 v6.49 - ISP real ip, OVPN server AND hap ax2 v7.11 - ISP local ip, Ovpn client) , in the tunnel i connect 2 networks over VLAN20 for Lan network and VLAN10 for IP TV.
The problem:
And Ok, everything work like a charm - the device in network are visible eache other, The TV work perfect, ping to everywhere is OK BUT,
Today i try connection from my network PC to other network PC through the tunnel(for example - 192.168.0.10/23 ↔ ovpn1(VLAN20) <->192.168.1.3/23)… and nothing but ping is OK, network folder resurse between two Sites are visible and accessible, BUT RDP is not possible!!!
In other wise when try connection in network - 192.168.0.1/24(in one site) the RDP connection is OK, it’s the same for other site RDP is OK in 192.168.1.1/24(other site)… BUT through the tunnel is not possible!!!
Before this new MT configuration(site to site over OVPN), I had EOIP connectivity and RDP was OK but then I had no VLANs!
Any suggestions?
Thanks!
