LOL. You’re absolutely right.
add admin-mac=CC:2D:E0:10:FD:6A auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] name=ether2-master speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=
ether6-master
set [ find default-name=ether7 ] advertise=
set [ find default-name=ether8 ] advertise=
set [ find default-name=ether9 ] advertise=
set [ find default-name=ether10 ] advertise=
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce
country=portugal disabled=no distance=indoors frequency=auto mode=ap-bridge
ssid=Alenprojectos wireless-protocol=802.11
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=WAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=
xxx wpa2-pre-shared-key=xxx
add authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys name=profile
supplicant-identity=MikroTik_xxx wpa-pre-shared-key=xxx
wpa2-pre-shared-key=xxxx
/interface wireless
add disabled=no mac-address=CE:2D:E0:10:FD:73 master-interface=wlan1 name=wlan2
security-profile=profile ssid=“xxxxx”
add name=dhcp ranges=10.0.0.10-10.0.0.250
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/interface bridge filter
add action=drop chain=forward in-interface=wlan2
add action=drop chain=forward out-interface=wlan2
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge comment=defconf interface=ether6-master
add bridge=bridge comment=defconf hw=no interface=sfp1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=ether7
add bridge=bridge interface=ether8
add bridge=bridge interface=ether9
add bridge=bridge interface=ether10
add bridge=bridge interface=wlan2
set discover-interface-list=discover
/interface l2tp-server server
set enabled=yes ipsec-secret=“axxxxxxxxxygjytjahergewe<HRGTFJYKY YU547
Q35T4 YREHFRSTJSJRTYA4YYEARG<FAA1SCq” use-ipsec=yes
add interface=sfp1 list=discover
add interface=ether2-master list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=ether6-master list=discover
add interface=ether7 list=discover
add interface=ether8 list=discover
add interface=ether9 list=discover
add interface=ether10 list=discover
add interface=wlan1 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add interface=ether1 list=WAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=10.0.0.254/8 comment=defconf interface=ether2-master network=
10.0.0.0
add address=192.168.0.209/24 interface=ether1 network=192.168.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
add address=10.0.0.0/8 comment=defconf gateway=10.0.0.254 netmask=8
set allow-remote-requests=yes servers=192.168.0.1,8.8.8.8
/ip dns static
add address=10.0.0.254 name=router
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=accept chain=input comment=“defconf: accept established,related”
add action=accept chain=input comment=“allow IPsec NAT” dst-port=4500 protocol=
udp
add action=accept chain=input comment=“allow IKE” dst-port=500 protocol=udp
add action=accept chain=input comment=“allow l2tp” dst-port=1701 protocol=udp
add action=accept chain=input comment=“allow pptp” dst-port=1723 protocol=tcp
add action=accept chain=input comment=“allow sstp” dst-port=443 protocol=tcp
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=
ether1
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=
ether1
add action=masquerade chain=srcnat comment=“masq. vpn traffic” src-address=
192.168.89.0/24
add action=dst-nat chain=dstnat dst-port=3389 protocol=tcp to-addresses=
xx.xx.xx.xx to-ports=3389
add distance=1 gateway=192.168.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8080
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd interface pages
set 0 interfaces=“sfp1,ether1,ether2-master,ether3,ether4,ether5,ether6-master,e
ther7,ether8,ether9,ether10”
/system clock
set time-zone-name=Europe/Lisbon
/system identity
set name=MikroTik_xx
/system scheduler
add interval=10m name=“IPCloud Force” on-event=“/ip cloud force-update” policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=dec/06/2018 start-time=11:40:21
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
