Re: FTP Blocking
I have ftp running on my LAN. I need to give access to mobile users via internet. I have assigned IP to WAN interface & did dsnt nat. Whiled testing when I try to connect in log is shows.
FDROP forward: input: WAN output: LAN proto TCP (SYN)
Regards,
Nadeem
Please, post /ip firewall nat rule used for the FTP server redirection.
chain=srcnat action=src-nat to-addresses=142.24.210.58 to-ports=0-65535 out-interface=WAN
src-address=192.168.0.0/24
Sorry that was wrong
chain=dstnat action=dst-nat to-addresses=192.168.0.6 to-ports=20-21 in-interface=WAN dst-address=142.24.210.68
dst-port=20-21 protocol=tcp
so, disable that firewall filter rule that drops the packet
I disabled all the drop rules still not working
Do you have active or passive FTP?
I have an active ftp running on linux os.
Then NAT should work. Try to forward other ports SSH/Telnet to your server (to make sure that public IP address works, which is given by the ISP).
I m able to ping this IP after natting.
How did you test FTP server?
Active FTP will not function when client-side is firewalled or client is behind NAT device which is not smart enough to alter IP addresses in FTP packets.
Passive FTP is better choice for mobile user, especially when they connect from different places.
Regards, Grzegorz.
My server is working fine, Mikrotik is dropping, FDROP forward:in WAN out :lan TCP (SYN)
I’m sure that your FTP server is working fine, I wrote about FTP clients.
I don’t know what FDROP in your log is, but the rest forward:in WAN out :lan TCP (SYN) say that packet is forwarded through router.
Look at this: http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
Post your full firewall RouterOS logs.
Regards, Grzegorz.
How this is joined together?
#1
Wed May 12, 2010 1:09 pm
#2
Posted: Tue May 11, 2010 2:35 pm
#1
Is my error message form my Mikrotik log
#2
Reply to chupaka as he asked to disable all drop rules in filewall.
Firstly you told that disabled drop rules, but still you see them in your log?
Yes thats correct even I m confused.
Set two logging rules, one for ‘input’ on WAN side, second for ‘forward’.
You will clearly see what is dropped and what is forwarded.
Regards, Grzegorz.
do you have ftp nat helper enabled (under IP - Firewall - Service Ports)?
I setted 2 rules for log its same FDROP forward in WAN out lan src-mac , proto TCP (SYN), and :21 len 48
