i inherited 2 mikrotik hex (rb750gr3) and i dont get them to work.
My goal is to get them into the delievery status (192.168.88.1 on first port) and configure them as i like via web interface.
Talking about only one now, the 2nd acts identical.
I tried to reset them as described in https://wiki.mikrotik.com/wiki/Manual:Reset#How_to_reset_configuration or https://help.mikrotik.com/docs/display/UM/hEX#hEX-Resetbutton (press reset until the usr led starts to flash, release), did not worked, the device still sends bootp requests like
15:55:08.429106 IP 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from b8:69:f4:fa:9a:0d, length 300
I tried the same with pressing reset before powering - same same.
If i boot it on a dhcp enabled network, it gets an ip and it is pingable, but i cannot reach any port on the assigned address.
Seems to run in a weird bridge mode?
14:12:41.647840 IP 192.168.48.4 > 192.168.48.2: ICMP echo reply, id 4, seq 6, length 64
^C
15 packets captured
15 packets received by filter
0 packets dropped by kernel
master# tcpdump -n -i enp2s0 host 192.168.48.4
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on enp2s0, link-type EN10MB (Ethernet), snapshot length 262144 bytes
14:13:02.789743 IP 192.168.48.2.44696 > 192.168.48.4.443: Flags [S], seq 3794430010, win 64240, options [mss 1460,sackOK,TS val 3372931634 ecr 0,nop,wscale 7], length 0
14:13:03.794565 IP 192.168.48.2.44696 > 192.168.48.4.443: Flags [S], seq 3794430010, win 64240, options [mss 1460,sackOK,TS val 3372932639 ecr 0,nop,wscale 7], length 0
14:13:05.810570 IP 192.168.48.2.44696 > 192.168.48.4.443: Flags [S], seq 3794430010, win 64240, options [mss 1460,sackOK,TS val 3372934655 ecr 0,nop,wscale 7], length 0
14:13:07.890523 ARP, Request who-has 192.168.48.4 tell 192.168.48.2, length 28
14:13:07.890932 ARP, Reply 192.168.48.4 is-at b8:69:f4:fa:9a:0d, length 46
I am a unix guy, but as i could not dig deeper into that i decided to use the windows gaming box and install winbox and netinstall, as i could not use one of my linux boxes - they are all headless and i read that i need to wire the device direct (without switches) to the netinstall host.
I was able to flash the current routeros (7.11.2) with ‘apply default config’ on it (‘installation finished successfully’), but still - it starts up in bootp and is not usable.
How can i get rid of this configuration?
I am a littlebit lost now and need some advise what i can try next…
Yes, i read a lot of similar questions here, in reddit, yada yada, but i could not find a similar problem (waiting with bootp, only icmp, no tcp answers) or solution so far.
Aleks
