i have a problem in re-installing my routerboard 1200.. wen i complete the procedure to connect to net install on the hyper terminal it says fine. wen i check my net install it doesnt show the router name for me to install the software. what can i do..?? pls help have been facing this for the past two weeks and i am not able to get a solution.
if you have correctly configured the netinstall software, check your firewall like windows and antivirus.
