RE : Problem with RB951G-2HND Router
Hi to All,
Good day. I am very new here in mikrotik forum. I would like to ask assistance for mikrotik users expertise here in this support group. Can you tell me what is causing the problem. Coz I already configured my mikrotik router with the proper configuration. Then after 2 days of using the router with no problem suddenly I get no internet connection. When I connect to the mikrotik router to check, I found out the problem is router tries to insert a different default gateway.
So to fix the issue from the IP>Address menu I try to delete this incorrect entry. I don’t know what is causing the problem.
Can anyone assist me. Thanks.
rodney
telling you what’s causing a problem in the configuration you ‘created’ with that little information provided ?
In Winbox, please open a terminal session, type
 /export hide-sensitive
and post the result here.
greets
