Re-sorting mangle rules order
So basically i got an mangle rules for download which get destination port as 443 as my first rule, and mark connection as “download_con”, and then i immediately create a new rules to mark packet for download_con with no passthrough.
Later on, i added 2 rules (same as above), same port but from a specific destination address. I suggest the rules that i add later didn’t work because of the mark packet rule for download_con. If so, is there any way to quickly change the order of the rules without deleting everying and re-enter again?
All chains are forward.
Thanks for the suggestion.
From terminal use “move” command
Or winbox drag and drop
