RE: WPA
Has anyone seen this in the logs for a ststion that associates then tries to obtain an IP then inediatly drops:
wireless,debug Wireless |: WLAN1: 00:0F:A3:26:D1:85 attempts to connect in 27-Apr 8:36:34.60 from 10.0.0.122
wireless,debug Wireless |: WLAN1: 00:0F:A3:26:D1:85 in local ACL, accept in 27-Apr 8:36:34.60 from 10.0.0.122
wireless,info Wireless |: 00:0F:A3:26:D1:85@WLAN1: connected in 27-Apr 8:36:34.60 from 10.0.0.122
wireless,info Wireless |: 00:0F:A3:26:D1:85@WLAN1: disconnected, decided to deauth: 4-way handshake timeout (15) in 27-Apr 8:36:37.25 from 10.0.0.122
wireless,debug Wireless |: WLAN1: reject 00:0F:A3:26:D1:85, banned (last failure - decided to deauth: 4-way handshake timeout (15)) in 27-Apr 8:36:38.44 from 10.0.0.122
wireless,debug Wireless |: WLAN1: reject 00:0F:A3:26:D1:85, banned (last failure - decided to deauth: 4-way handshake timeout (15)) in 27-Apr 8:36:45.97 from 10.0.0.122
I am looking for a quick answer si I dont have to wade thru a mile of text to figure out what is up..
I have checked the pre shared keys and the protocols (WPA PSK) agree also I have updated the XP driver for the airlink card (old would not even link)
Things that make you go HMMMMM…
Craig
Is compression off?
Did not check that one, I will take a look…
Compression = OFF..
Things that make you go “Hmmmmmmmm”…
Craig
