Hello from Austria…
This is my first entry here but with a read a ot and so far my system works well. 1100ahx4
My question is:
i have a domain as example : www.xyz.com
With my mobile phone i can connect to my webcam by: wwww.xyz.com:1234
To have this there is a dst-NAT rule in my router with dst-port 1234 to the local ip:192.168.1.1 dport 1234
This works well. Normall port forwarding
But:
If my mobile phone is in the LAN and i enter the same webcam adress wwww.xyz.com:1234 i cant reach the cam.
But if i enter the correct local LAN ip for the cam 192.168.1.1:1234 i can reach it
This means, with my public domain name i cant reach any device inside my LAN. From inside the LAN
I guess this is solvable but how? Maybe with dstnat ???
Thanks for your hints
faxxe
