At some point decided to switch from global https://my.zerotier.com to controller located on MT. Now I can reach ZT addresses from LAN but can not reach LAN from ZT.
My config:
> print detail
Flags: X - disabled, R - online; F - tcp-fallback
0 R ;;; ZeroTier Central controller - https://my.zerotier.com/
name="zt1" disabled=no port=9993
identity="914..."
interfaces=all route-distance=1
identity.public="914..."
state="running"
> /zerotier/controller/print detail
Flags: X - disabled, I - inactive
0 I disabled=no instance=zt1 name="ZTCP1" network="914..." private=yes broadcast=yes mtu=2800 multicast-limit=32 ip-range=12.12.12.10-12.12.12.255 ip6-rfc4193=no ip6-6plane=no routes=192.168.88.0@12.12.12.12,12.12.12.0
> /zerotier/interface/print detail
Flags: D - dynamic, X - disabled; R - running
0 name="zti1" mac-address=8E:63:00:00:00:00 mtu=2800 arp-timeout=auto network="914..." instance=zt1 allow-managed=yes allow-global=no allow-default=no
> /ip/firewall/filter/print
Flags: X - disabled, I - invalid; D - dynamic
0 chain=forward action=accept in-interface=zti1
1 chain=input action=accept in-interface=zti1
2 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
3 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
4 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
5 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
6 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
7 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
8 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
9 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
10 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related
11 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
12 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
13 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
> /ip/firewall/nat/print detail
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix="" ipsec-policy=out,none
> /ip/route/print detail
Flags: D - dynamic; X - disabled, I - inactive, A - active; c - connect, s - static, r - rip, b - bgp, o - ospf, i - is-is, d - dhcp, v - vpn, m - modem, y - bgp-mpls-vpn; H - hw-offloaded; + - ecmp
DAd dst-address=0.0.0.0/0 routing-table=main gateway=10.0.1.254 immediate-gw=10.0.1.254%ether1 distance=1 scope=30 target-scope=10 vrf-interface=ether1 suppress-hw-offload=no
DAc dst-address=10.0.1.0/24 routing-table=main gateway=ether1 immediate-gw=ether1 distance=0 scope=10 suppress-hw-offload=no local-address=10.0.1.31%ether1
DAc dst-address=12.12.12.0/24 routing-table=main gateway=zti1 immediate-gw=zti1 distance=0 scope=10 suppress-hw-offload=no local-address=12.12.12.12%zti1
DAc dst-address=192.168.88.0/24 routing-table=main gateway=bridge immediate-gw=bridge distance=0 scope=10 suppress-hw-offload=no local-address=192.168.88.1%bridge
> /ip/address/print detail
0 ;;; defconf
address=192.168.88.1/24 network=192.168.88.0 interface=bridge actual-interface=bridge
1 D address=10.0.1.31/24 network=10.0.1.0 interface=ether1 actual-interface=ether1
2 address=12.12.12.12/24 network=12.12.12.0 interface=zti1 actual-interface=zti1
The ZeroTier interface works just like an Ethernet interface. You need to allow and set up proper routing between your LAN and the ZT subnet, or alternatively use src-nat from ZT to the LAN.
I assume you’ve already added your LAN in ZeroTier Central > Networks > Advanced Settings > Managed Routes.
Well, the /zerotier/controller is marked as “I” INVALID, so that a first level problem here. You have
If it’s invalid, the controller is not running. Specifically I think the routes need use the CIDR subnet for (LAN) route to be: routes=192.168.88.0@12.12.12.12,12.12.12.0**/24**
…but not 100% that your only issue since using the controller on Mikrotik does make this more complex.
Alright, dual stack (hmm…). It might be a routing issue since there aren’t any replay packets and I don’t see any ICMP packets coming in. As a temporary workaround for IPv4, try a source NAT approach using the command below. Just replace ZZZZZ with your ZT subnet and XXXXX with the name of your LAN interface, like ether1 or bridge, etc.:
Run a packet sniffer again, and this time let it ping every second for 10 seconds or more while recording. Btw, what ZT subnet and other settings are you using? Global, etc.. You don’t need to censor the subnets for your LAN or ZT if they’re private, it’ll make it easier to follow the trace.
