Hello everyone
It’s my first post in this forum. Please excuse me in advance because my English language is very bad.
I have an Hex Poe Routerbord connect via Wan to link bridge wireless Sta Ubiquiti Litebeam AC. Link is long ~ 115 ft and the Ap Litebeam AC is connect neighbor to the bording router openwrt that is the gateway.
My problem is when I’m connect with laptop (or other devices) lan side, the link is unreachable while the gateway is reachable. To be able access to the link Ubiquiti I use ssh tunnel on the mikrotik Hex Poe or Openwrt gateway.
Openwrt gateway → 192.168.255.1
Ap Litebeam → 192.168.255.2
Sta Litebeam → 192.168.255.3
Hex Poe → 192.168.255.4
p.s. Hex Poe ports are configured as bridge and I used static route to configure my Pan network.
Below, the routes on Hex Poe:
[admin@MikroMinkia_A] > ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.255.4 192.168.255.1 1
1 X S ;;; LAN_Loia
10.0.1.0/24 172.16.0.1 172.16.0.4 1
2 A S ;;; LAN_Maurizio
10.1.0.0/24 172.16.0.1 172.16.0.4 1
3 X S ;;; prova rotta
10.255.255.0/24 172.16.0.1 172.16.0.4 1
4 A S ;;; routes_loia
172.16.0.0/16 172.16.0.1 172.16.0.4 1
5 ADC 172.16.0.0/29 172.16.0.1 bridge 0
6 X S 172.16.0.8/29 172.16.0.1 172.16.0.4 1
7 A S 172.17.0.0/16 172.16.0.1 172.16.0.4 1
8 A S ;;; route_utenza
172.30.0.0/24 172.30.0.1 172.30.0.2 1
9 ADC 172.30.0.0/29 172.30.0.1 bridge 0
10 X S ;;; route_roverato
172.31.0.0/24 172.31.0.4 1
11 ADC 172.31.0.0/29 172.31.0.1 bridge 0
12 A S ;;; Route interna utenza
192.168.0.0/22 172.30.0.1 172.30.0.2 1
13 ADC 192.168.255.0/24 192.168.255.4 ether1 0
14 X S 192.168.255.0/24 192.168.255.1 1
15 X S ;;; angelini2virgili
192.168.255.0/29 192.168.255.4 ether1 1
Below the routes of the openwrt gateway:
root@modemtim:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.100.1 0.0.0.0 UG 0 0 0 pppoe-wan
10.0.0.0 192.168.255.4 255.0.0.0 UG 1 0 0 eth0
172.16.0.0 192.168.255.4 255.240.0.0 UG 1 0 0 eth0
192.168.0.0 192.168.255.4 255.255.224.0 UG 1 0 0 eth0
192.168.100.1 * 255.255.255.255 UH 0 0 0 pppoe-wan
192.168.168.0 * 255.255.255.128 U 0 0 0 wl0_1
192.168.168.128 * 255.255.255.128 U 0 0 0 wl1_1
192.168.169.0 * 255.255.255.128 U 0 0 0 eth4
192.168.254.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.255.0 * 255.255.255.0 U 0 0 0 eth0
192.168.255.0 192.168.255.4 255.255.255.0 UG 1 0 0 eth0
The Lan interface of the openwrt gateway that is connected to the Ap Litebeam is eth0. The others interfaces are used to the local network office’s business.
If the information posted is not enough, please tell me and I will post it to give you the opportunity to help me with more productivity
