Reaching device
Hi all!
I have some difficulties reaching the device that brings me the Internet connection.
This is the situation: the port 1 of the router (hAP lite v. 6.48.3) is statically configured with my public IP address, and routes go accordingly. Ports from 2 to 4 plus wlan are bridged and are part of the LAN.
Everything works fine: I can surf the web, reaching other computers on the LAN and so on.
The problem is that I would like to reach the device that is connected to the port 1. It’s a station that is configured with the 10.1.20.1/24 address. If I connect directly to the device configuring statically my computer with some random address like 10.1.20.100/24 I can reach it and see the working parameters.
I’ve tried to put a switch before the router, and enter in both port 1 and a port of the bridge, but I don’t know how to configure the bridge itself to reach the device.
Any adivice is appreciated!
Thank you
Denis
remove what you have tryed to do,
put 10.1.20.100/24 on ether1
paste this on terminal
/ip fire nat
add action=src-nat chain=srcnat dst-address=10.1.20.1 to-addresses=10.1.20.100
You now can open 10.1.20.1, but only if some firewall rules do not obstacle it.
Hi!
Thank you for your reply.
I’ve cleaned up the configuration and tryed what you suggested me, but it doesnt work.
Right now, the complete setup is this one, maybe with all the parameters it’s easier
add admin-mac=*** auto-mac=no name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="us 2.4 5.8" disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=*** wireless-protocol=802.11
/interface pwr-line
set [ find default-name=pwr-line1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik wpa2-pre-shared-key=***
add name=default-dhcp ranges=192.168.1.180-192.168.1.250
add add-arp=yes address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=pwr-line1
add bridge=bridge interface=wlan1
add interface=bridge list=LAN
add interface=ether1 list=WAN
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
add address=*** interface=ether1 network=***
add address=10.1.20.100/24 interface=ether1 network=10.1.20.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf domain=lan.local gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8,208.67.222.222,8.8.4.4,208.67.220.220
/ip dns static
add address=192.168.1.1 comment=defconf name=router.local.lan
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=WAN
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
add distance=1 gateway=*** pref-src=*** scope=10
/ip service
set telnet disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Rome
/tool mac-server
/tool mac-server mac-winbox
Thank you!
