Hi itsh.net
I found your post because I had similar math problems with the bytes command. The basic problem is that “bytes” is defined as uploadedbytes/downloadedbytes and not two seperate variables such as tx-bytes and rx-bytes.
I wrote a quick script to mail all queues on a certain router with their upload and download statistics. Feel free to use and modify to your needs! G
:log info “Starting QUEUE Statistics Checker”
#####DEFINE VARIABLES#####
:local slashchecker
:local slashcheckertotal
:local bytecountedup
:local bytecounteddown
:local megcountedup
:local megcounteddown
:local slashcounter
:local precalcbytes
:local pickbegin
:local pickend
:local slashcounted
:local slashcounted1
:local numberofqueues
:local test
:local interfacename
:local emailvariable
:local highsitename
:local fromemailaddress
:local toemailaddress
#####VARIABLES DEFINED#####
########## CHANGE INDIVIDUAL DETAILS HERE: ##########
:set fromemailaddress “highsite@domain.co.za”
:set toemailaddress “admin@domain.co.za”
########## END OF INDIVIDUAL DETAILS ##########
#####COUNT NUMBER OF QUEUES#####
:set numberofqueues [/queue simple print count-only]
:set highsitename [/system identity get name]
##ADD DETAILS TO E-MAIL VARIABLE##
:set emailvariable "QUEUE STATISTICS FOR:
$highsitename
TOTAL NUMBER OF QUEUES: $numberofqueues"
##ADD DETAILS TO E-MAIL VARIABLE DONE##
#####BEGIN MAIN LOOP FOR QUEUE PROCESSING#####
/queue simple
:foreach n in=[/queue simple find priority=8] do={
:local interfacename [/queue simple get [$n] name]
#####SEPERATE UP/DOWN BYTES FROM QUEUE#####
##PRESET VARIABLES##
:local precalcbytes [:pick [/queue simple get [$n] bytes] 0 30]
:set slashcheckertotal $precalcbytes
:set pickbegin 1
:set pickend 2
:set slashcounter 0
#####START SLASH CHECKER#####
/queue simple
:for i from=1 to=20 do={
:set pickbegin (pickbegin + 1)
:set pickend (pickend + 1)
:set slashchecker [:pick $slashcheckertotal $pickbegin $pickend]
:if ($slashchecker = “/”) do={
:set slashcounted $pickbegin } else={ :set slashcounter ($slashcounter +1)}
#:log info “SLASHCOUNTED: $slashcounted”
#####SLASHCHECKER LOOP END#####
#####GOT SLASH PICK COUNT, STARTING BYTES UP AND DOWN SPLIT#####
:set slashcounted1 ($slashcounted + 1)
:set bytecountedup [:pick $precalcbytes 0 $slashcounted]
:set bytecounteddown [:pick $precalcbytes $slashcounted1 30]
:set megcountedup ($bytecountedup / 1000000)
:set megcounteddown ($bytecounteddown / 1000000)
#:log info “INTERFACE NAME: $interfacename”
#:log info “PRECALCBYTES: $precalcbytes”
#:log info “BYTECOUNTEDUP $bytecountedup BYTES”
#:log info “BYTECOUNTEDDOWN $bytecounteddown BYTES”
#:log info “MEGCOUNTEDUP $megcountedup MB”
#:log info “MEGCOUNTEDDOWN $megcounteddown MB”
#:log info " "
#:log info " "
##ADD ABOVE INFO TO EMAIL VARIABLE##
:set emailvariable "$emailvariable
QUEUE NAME:\t\t\t$interfacename
TOTAL BYTES:\t\t$precalcbytes
UPLOADED BYTES:\t\t$megcountedup MB
DOWNLOADED BYTES:\t\t$megcounteddown MB
##UPDATE OF EMAIL VARIABLE DONE##
#####END OF QUEUE PROCCESSOR LOOP#####
#####SENDING DETAIL TO EMAIL#####
:set emailvariable “$emailvariable
END OF QUEUE STATISTICS FOR: $highsitename”
/tool e-mail send from=$fromemailaddress to=$toemailaddress server=196.25.240.94 subject=“$highsitename QUEUE Statistics” body=$emailvariable
#####END OF SENDING EMAIL#####
:log info “Total number of queues processed: $numberofqueues”
:log info “QUEUE Statistics Check DONE and E-Mailed to $toemailaddress”
G
