i wanted to display some RouterOS values on a LCD hooked up to an ESP8266 which is connected to a Mikrotik Wifi network.
Background Story:
We have a small train that should get Wifi over LTE along the track for our customers and to send the GPS Position of the train to a server. For this i want to get a Mikrotik router since i am familiar with these. To check the LTE, GPS and Internet Status I want to place an ESP8266 with a LCD/OLED Display at the driver’s cab so that he knows whats going on.
With a Raspberry Pi this is possible but it needs to be booted up and shut down properly and i want to keep it stupid and simple so i decided to use an ESP8266
I checked out the Mikrotik API documentation and was overwhelmed and i understood nothing. I also tried to read values via Telnet but this is so messy with the libraries i found.
Can someone please help me find a solution for that problem?
Hi, that Router would have been my choice anyways (just without US).
I found a way now. The ESP8266 runs a http web server for post requests. Now i can send a post request from the mikrotik with scripts to the ESP. The ESP then displays the Value on the tiny OLED screen.
If someone wants the code i can modify it a bit and maybe upload it to Github.
Hello Sir.. Have a blessed day.. I’m interested. please send me your code and I’ll try you project.. what is your Githud account.? or send me an email: jeffcastaneda31@gmail.com
Hi, i don’t have a github Account yet but i’ll try to get the code optimized and published there in the next few days. I’ll let you know when i’m done.
Please use “Post Reply” button below the post when you do reply on a post. Not need to Quote the whole post above you. And Quoting the Quoting the Quoting just fills up the thread.
@jeppu31
Hi, i just reworked the code, added some small Features, cleaned it up, documented the code and wrote a description for it today.
I am finally done after working on it for several hours today, couldn’t do it earlier because i was away from home for a few days.
You can find my project here:
