Reading CPU temperature through serial port ?
Hello All,
As anyone tried reading CPU temperature through the serial port using an Arduino ?
I’m trying to find a way to fetch this value.
Thank you
I don’t but mayby you can use this
http://www.papouch.com/en/shop/product/tm-routerboard-thermometer-mikrotik/
send “/system health print” to the console and parse the response for “temperature: C”
Thanks to both of you. I was thinking about “/system health print” in the first place but would you happen to know if TX/RX and GND are enough to send and read data of the Mikrotik using Arduino ?
Thank you
Edit: Also I’m wondering if this could be a solution as I only want temperature info, not full system management (even if user/password can be used I guess): http://wiki.mikrotik.com/wiki/Sending_text_out_over_a_serial_port
I just tried to send text trough serial port but all I get is garbage even though I follow Mikrotik’s serial pinout (DB9F) and I configured both ends with same settings (115200 8N1).
Calling this script http://wiki.mikrotik.com/wiki/Sending_text_out_over_a_serial_port is seen like this on my machine:
[�*�/5��
Using /system serial-terminal serial0 doesn’t give better results.
Any idea ?
Thank you!
Are you using an arduino module something like this ?
http://www.dx.com/es/p/rs232-to-ttl-serial-communications-module-w-indicator-blue-black-221240
It have a tx/rx for connect to arduino.
sent from my mobile phone using tapatalk
I’m using this:
http://arduino.cc/en/Main/USBSerial
And actually it’s plugged to my laptop simply reading data off this module, it works fine when connecting to other serial ports (i.e. WNDR3700 for recovery).
