Reading Modbus coils and registers
I’m trying to create a script reading Modbus coils and registers with the new command, transceive and publish it with MQTT to a broker.
In the Terminal, the values return as expected using the transceive command, but cannot publish it with MQTT.
This is the line I use for the ModBus query:
:local modbus ([/iot modbus transceive address=1 function=3 data=00090010]->"values")
Then publish this with MQTT:
:local message "{$[:tostr $modbus]}"
/iot mqtt publish broker=$broker topic=$topic message="{\"Values\":\"$message\"}"
This produces an empty string.
Is there an option to get the values from the ModBus qurery? (The “old” read holding registers is not an option, because I must use other than 3 codes also.)
Thank you!
Forgot about as-value
:local modbus ([/iot modbus transceive address=1 function=3 data=00090010 as-value]->"values")
When the RS485 device is unavailable, the script will throw error, so make a modbus request with error handling
:local modbus
:local message
:do { :set modbus [/iot modbus transceive address=3 function=3 data=00090010 as-value] } on-error={}
:if ([:typeof $modbus] != "nothing") do={
  :set message "\"{$[:tostr ($modbus->"values")]}\""
} else={
  :set message "null"
:do={ /iot mqtt publish broker=$broker topic=$topic message="{\"Values\":$message}" } on-error={}
I don’t know whether it is necessary to send a message to the broker in the error handler, check the script with the broker-server turned off. Also check how to send a message to the broker with missing parameters, null with or without quotes, or some other way.
