OK, so maybe “adventure” is a little hyperbole . Maybe journey of discovery is better.
So I am lucky enough to have in front of me 2 separate hex routers until my son picks his up, so I figured this would be a perfect time to play around with one offline and learn VLANs so that I can properly set up 2 separate LANs the way that everyone is telling me is the correct way. Currently I set have it set up with 2 separate bridges and I have been told that, while that will work (and it is working fine), that is not the correct way to do it. VLANs is the correct way. I set it up the way that I did because I understood that way and I needed to get online ASAP. But now I have more time and an offline router to mess with so I am ready to learn.
As I understand it one of the main reasons to use VLAN as opposed to 2 bridges is that there is a switch chip which can only accommodate 1 bridge. If you have 2 bridges then the second bridge cannot use this chip and this results in slower performance. I did some speed test and found no difference in speed but again, I only have a small home LAN that does nothing really so I may not experience and performance degradation. But I still want to learn how to do things the preferred way.
My goal is very simple. I have a small home network with no fancy anything. I have a few PCs on LAN1 which is my personal LAN. I have a LAN2 that is for guests and all the various junk that you have to plug in nowadays like streaming stuff etc… which I prefer to keep separate.
I did read the often linked to thread that many say is the best topic on learning and setting up VLANs, but I’m sorry to say that, it might be a great thread for well versed people, it is not really that good for beginners; even a somewhat advanced beginner such as myself. I was not able to figure out what to do from that topic.
So I guess my first question is … assuming a stock default hex router with all factory default settings (only 1 default bridge, default DHCP, default firewall rules etc…) except for the admin password, how does one go about setting up 2 separate VLANs?
I assume that what I will have in the end is VLAN10 (192.168.88.x) which will be my personal LAN with 2 ports (ether4 & 5) and VLAN20 (192.168.2.x) which will be the “guest” LAN for lack of a better term (ether 2 & 3), all residing on the same bridge.
