Okay for some reason I am not logging any of my rules anymore.
You know, the ones that are associated with log=yes and a prefix entry.
Everything looks good in my disk configuration and selections, nothing seems changed.
All I am seeing now is basically assigns and de-assigns to DHCP server leases and any changes I make to filter settings.
If this keeps up I am going to have to go to the LOG house, where there are only four white padded walls.
The SD card I used is named properly in the log file and is getting filled with the above limited entries (yes all is selected to ensure I am not missing anything).
Turn scripting engin OFF /system logging disable 0
Turn scripting engin ON /system logging enable 0;
If certain scripts get triggered prematurely then there could be a level of command confusion:-) so if a script is fired and another script gets also fired at the same time its possible that logging could be turned off all depending on the timing and order of processing,
Well I did that and guess what… ONE, one out of many started working. What gives???
Does it matter perhaps if I made the rules using another user name, perhaps thats what happened and thus some rules are not being used but in that case they wouldnt show right?
Grasping at invisible straws here.
Take ownership of the rules and see if that changes the behavior … i have not seen the behavior you describe so I cannot comment on why this may be happening.
Well of course not LOL, you are not an accomplished master tester (screwer upper) like me.
How is that done? I don’t see where the ownership is indicated??
Hmm I will have to change routers and see. What if name was removed?
Do I have to delete a rule and remake for it to function?
This is all unwritten and not visible and thus a missing link in OS that needs cleaning up.
