Really simple question about RB3011UiAS-RM
I’m sorry for the noob questione bit it’s Not specified on the site. Does this model have wireless ap?
Thanks in advance,
  • Black
No it does not. There are other devices with wireless.
Thanks for the fast answer!
I was thinking about buying a router with 10 1Gigabit ports and a wireless system in it. Any advice?
Best advice is to buy two devices. Always use seperate ap and router/switch.
RB4011 is coming: https://mikrotik.com/product/rb4011igs_5hacq2hnd_in
Thank you all for the answers! Really appreciate it
Before You jump the gun, take a look at the block diagram.
The 4011, for example. It does have 10 Gb ports - but they are spread in two switches - and each switch has a 2,5Gb link with the CPU.
This can be ok - or not - for Your use case. Best advice is: buy a router and a switch. Each device will do only one thing - and will do it well.
